Abs dtc c0161
Old 10-30-2012 | 02:35 PM
GreenMachine's Avatar
Angry Abs dtc c0161
Hey guys!
I've been scouring the net for over a month for an answer.
The DTC mentions a short or an open circuit related to the brake lamp switch;
So so far here is what I have done:
1) Replaced the brake lamp switch itself
2) Replaced the ebcm
I still get the DTC code even after clearing it w/ my obdII scan tool.
This is where it gets weird:
I checked all fuses (no fuses blown); The brakes work (the 2 rear lamps AND the upper 3rd)
**I checked the voltage coming through the brake lamp switch:
With the pedal released I get:
a) 7.5 volts on the white wire
b) 13.7 volts on orange wire
c) 13.6v on brown
d) 13.6v on purple
e) 13.5v on light green wire w/ tracer
f) 13.5v on teal wire w/ tracer.
The DTC clears only when the pedal is depressed (pushed in) b/c the voltage readings are regular.
Isn't one of the wires (I'm guessing the white wire) supposed to be absolute 0 with the brake pedal released???
How am I getting a voltage reading on that bad boy? What should I be looking for?
Thanks in advance for any guidance....I'm running out of ideas
Old 10-31-2012 | 09:53 PM
bflorin's Avatar
Put a test light on A or inline w/ your voltage meter and see if that voltage is real.
88House
01-25-2013 10:26 AM
mallesham hb
01-22-2012 08:17 AM
Calgary
08-01-2010 12:29 AM
motley1987
05-18-2009 01:51 PM
Dlinzy
09-04-2008 04:49 PM
