5-speed & larger tires
Been around here for a while & understand that you can put a 35" tire on with a simple leveling. However, my question is since the '07 5-speed is such a dog with the 265 tire combination compared to the automatic, will I have drivability issues with the larger tires in respect to power?? After all.... I already am being passed by mopeds on interstate enterance ramps!!
I just upgraded from factory 265's to DuraTec 285's on my '06 auto. Subjectively, it's a little slower overall with the most noticable performance hit at highway speeds. I didn't bother taking any before and after acceleration times so nothing objective to offer.
Even so, I'm sticking with 285's from now on!
Well, that was my question!! I am certain I will be loosing power. I was just wondering if the loss of power would be such as to render 5th gear useless, or make me more of an obstacle getting on the highway. Not to mention hindering off road capabilities.
I've found that the biggest hit with my auto is recovering highway speed after a slowdown. In other words, I now need to use more throttle going back up to 70 after a slowdown than I've been used to over the past 3-years.
Just a guess on my part but you will not loose 5th gear on the highway if you upgrade to 285's. You will just have to reach for 4th a little more often and use more throttle.
I'm very happy with this new compromise but then again I don't understand the need for fast trucks. I like my trucks capable and my cars fast instead. At any rate, my '06 is still about as fast as most any pre-late 90's, midsize, 4WD truck that I have driven.
I hope my 285 experience helps, someone that knows what's up with 305's should chime in soon.
I haven't taken them major off-road yet or even through snow but they really look awesome.
Aside from the slight hit on acceleration, there's also a bit more "driving on snow tires" sensation. The rear axle is looser on the DuraTracs compared to the factory Wranglers.
If you typically drive only through dry conditions, there are likely better choices that could also perform better on the street.
way2real
12-09-2012 11:37 AM
ador
09-22-2010 12:16 PM
cjlv_1
08-06-2010 01:38 PM
07HummerH3
19
11-18-2007 08:32 PM
