32" vs 35"
32" vs 35"
Ok, I need to know if it's really worth the price difference to go from stocks to 35s.... Can someone out there shoot a few shots of a stock leveled h3 next to a leveled h3 with 35s? I'm really chewing this one over.
Also, does anyone know of a site that sells used tires that I could buy these from?
I've used and really liked the following on our previous GMC Envoy: Michelin OEM LTX, Goodyear Fortera, and Goodyear Wrangler. Michelin even makes "green" light truck tires now so there may even be additional fuel savings possible beyond what you can expect from going all-season instead of on-off road.
32" tires really aren't that small; jeeper's put 32's on as an aftermarket upgrade; they cant fit 35's without a lift. Also, new FX4 F150 offroad-package pickups come with like 28" or 30" tires; if this helps put things into perspective.
But honestly, I'd go with 33's. They are a perfect mix between "go-anywhere" and "good street manners". 35's are more of a "go-ANYWHERE".. but will yield more noise and less mpg.
BUT, as seen above, the 35's over stock 32's make a HUGE lift difference. Which means no bottoming out, no high-centering, climbing a higher step, etc.
i have 35in goodyear duratracs and i barely get any road noise, if you are planing on offroading more then get 35s if it is a once every month or so thing then get 32s or 33s, but I HIGHLY recommend duratracs. i would post a pic of mine next to a stock hummer but there are no other h3's in DE.... just jeeps
Michelin and Goodyear have been my favorites for quite a while. If you go with an all-season tire instead of an on-off road tire from one of these brands, your H3 will likely ride more like an Escalade!
the only noise i get is a slight hum when i reach 55 and it goes away when i pass 60mph, the reason why duratracs dont have road noise is because of the gaps between the treads, it is not as wide as other offroad tires and also there are no parts of the tread that are uneven like swampers and other mudders, and gas mileage wasnt bad at all man, i was getting 18 highway on my trip from IN to DE, city i get about 14
