28 inch rims wheel SPACER
I have 28 inch rims and 295/25/28 tires for my 2007 H3. They dont bolt on because of the big hubs on the H3. Therefore I need SPACERS to clear the hubs. The spacer needs to clear my original lugs so that i can bolt on the rims. My question is if I use 1.5 inch spacers or 2 inch. Believe it or not, if they did bolt on, they wouldnt rub. The problem is just that the hubs are too large. I measured how how much space is needed to clear and its roughly 1.25 inches. The problem is I dont know how much meat is on the spacer where the lugs tighten it on. Im thinking 1.5 inch is cutting it close and maybe 2 inch spacers would be safe. Anyone know if 1.5 inch spacers clear the original lugs so you have a flush surface to bolt a rim?
Here are the 2 inch spacers
the center bore shouldnt be messed with as it takes away from the integrity of the rim i was told. Im only going to drive with the spacers and rims 3 months a year..if that makes a difference
Remember unless you have them mounted 100% correct you are not only putting your life in danger, but everyone else on the road around you, mother, children, fathers, soldiers, everyone and you are liable.
My advise is to go to a reputable tire/wheel shop an discuss it with them, and get their recommendations and have them mount them if you are unsure in any way.
Doesn't matter how nice the rims look if the hummer is in a junkyard because you figured it would only be a few months riding in style.
jsbihn
01-06-2015 11:48 PM
roycel
01-09-2011 01:58 PM
bhoy27h3
04-15-2009 12:14 PM
bhoy27h3
04-11-2009 11:56 AM
