2008 Hummer H3 Rough Country Leveling kit help!?
Hey everyone. I could use some help. I paid 70$ for the 3 inch Rough Country leveling lift kit. To pay to have someone else install it is like 150$. I wanna do it myself but don't really know how. I have every tool required and an extra set of hands if needed. How hard is installation of this lift and should I just suck it up and cut my losses and have it done for me? Thanks for the help! Much Love!
Sincerely, Mr. H3
Sincerely, Mr. H3
A 1/2" drive breaker bar and 27mm socket is all you need to turn the torsion bar bolts. Measure from center of the axle shaft to the wheel well. Do not exceed 24". 23.50" is max for safe CV shaft and steering angles. Stock should be 22.50". No adjustment to the rear needed. Adjust to desired height, drive around and work the suspension. Re-measure and adjust until it settles where you want it. Then get an alignment.
https://www.trailduty.com/product_in...0ee2f9d53aa9df
Trail Duty Hummer H3 Extended Front Bump Stops
Two Sizes: +1/2" and +1"
If you have leveled the front end of your Hummer H3 by adjusting the torsion bars, you may well notice that you suffer from front end dive when braking and excessive suspension movement.
The Trail Duty Extended Bump Stops will cure this problem. Available in two sizes, +1/2" and +1", these poly bump stops will help prevent nose dive and reduce excessive suspension movement.
Important: The best way to assess which bump stop size is suitable for your vehicle is to measure the distance between the existing bump stop and the lower a-arm, (after adjusting the torsion bars). Ideally you want the new bump stops to have small gap, 1/8" - 1/4". It is important the new bump stops are not resting on the a-arm or supporting the vehicle weight.
The +1/2" bump stops are recommended for most applications. +1" are not recommended for off-road use.
Chad1557
01-17-2014 12:54 PM
Llamafood
01-11-2012 07:16 PM
rhill20
39
07-14-2008 04:50 PM
ReconH3
05-06-2008 12:05 AM
GarrettMoore
05-05-2007 11:29 AM
