2008 H3 5cyl Radiator Replacement
Hello all. I need to replace the Rad in my 2008, H3 5cyl. I did some searching on here and never could find a decent post to explain the ins and outs of replacing this part. How difficult is it? Any hiddend issues I should look for? I have put lots of Rads in but never messed with a Hummer before.
Any advice would be appreciated.
If you have not done a radiator in a long time, it is still easy, but done a little different than the days of yesteryear.
No radiator drain, you remove the lower radiator hose to drain the coolant. A round hose clamp pliers and fan clutch wrench will make it a breeze.
Once the fan is off, you can slide the shroud up out of the truck by removing the radiator end of the upper hose, then you will see there are a top center and top each side mounts that need to be unbolted after the trans cooler lines (at the bottom) are disconnected to lift the radiator out.
Good luck.
sattv
08-08-2012 06:30 PM
jdrew
04-13-2007 02:15 PM
