2007 Hummer H3 Won't start
Old 03-06-2014 | 12:45 AM
Hummerbass's Avatar
I'm aware of the security feature, but that's not the case here. My hummer cranks, but makes loud noise and doesn't stay cranked without me stepping on gas. I have my hummer with a mechanic now, and he's looking through all possibilities
Old 03-07-2014 | 04:00 AM
Timing Chain!
Old 03-07-2014 | 04:17 AM
Hummerbass's Avatar
Will tell mechanic to check that tomorrow. Thank you guys.
Old 03-14-2014 | 03:48 AM
force0009's Avatar
Any update on what the problem was? Mine had a similar issue but I replaced the camshaft sensors/ vvt solenoid and changed the oil, after that the problem seemed to correct itself.
Old 03-15-2014 | 08:21 AM
Hummerbass's Avatar
Mechanic said engine is trash, spun rod bearing
Old 03-27-2014 | 12:22 AM
Hummerbass's Avatar
Ok so I has new motor installed, and still hummer isn't staying cranked. Can someone please assist me with this issue.
When I stick key in ignition, car turns on, cranks, spins over, but does not stay cranked unless I step on gas pedal.
Old 03-27-2014 | 05:20 AM
DC_Roller's Avatar
Is your security light flashing, that was the issue with mine, the starter kill was engaged because of my remote start.
Old 03-27-2014 | 06:51 AM
Hummerbass's Avatar
Not sure, what did you do to have it fixed? I have viper remote start on it. Remote start hasn't been working for quite sometime
Old 03-27-2014 | 09:15 AM
Do you have a sunroof? If so, have you ever got the passenger side floor wet?
Old 03-27-2014 | 03:14 PM
Hummerbass's Avatar
Yes I have a sunroof, and I don't believe I have gotten it wet. But if it has, what would happen? Would anything I described above happen?
