2006 H3 transfer case motor wire diagram
Need help with wire connector on the transfer case motor for a 2006 H3. All the pins were pulled out of the connector and the wire harness has different color wires. How do the wires match up with the wire harness?
thanks
Every wire diagram I've seen dose not show the colors for the motor. The motor/encoder has solid color which dose not match the striped colors of the wire harness. For a photo of the wires on the motor go to Product Detail
you may need to look at the connector pin numbers and wire info from the diagram. its tricky to get the conn oriented right,wire end etc.
my diagram shows all the same but i believe you. you need to look at pin numbers/letters
Eddie Omegax
02-25-2015 12:52 PM
alex2mil
07-18-2011 11:19 AM
ozofoe
02-22-2010 06:18 PM
