2004 H2 persistent P1125 code. (need help)
#52
I'm assuming i have a shot bearing on the same side, but why change the half shafts and hubs? Do you think one of the two is making the seal fail over and over?
#53
I replaced the front left axle stub seal twice and the inner side bearing adjuster nut seal once on the same side.
I purchased all those items from Detroit Axle and have had no issues with them. The only other thing I wish I had done was upgrade my rotors while it was apart.
Tim
#54
Update!!!
http://imgur.com/a/Uyb3I
I just pulled the transfer case and sure enough the was plastic pieces everywhere! looks like part of the lockup shift assembly. The plastic shift fork is in good shape but i would replace if i can find a metal one.
Should i replace all the bearings since im in there? and i wonder if my tachometer fluctuation was from the transfer case shift fork drifting in and out of 4hi and 4hilock??? I really hope this is the main cause of all my problems......
Also while under the hood i found water pump gasket leaking as well as power steering fluid coming out from somewhere!....yahooooo.
#56
Update!
I have a low whine from the under carriage somewhere, i'm assuming its the transfer case i just rebuilt. It starts after being driven and warmed a little then its very noticeable when rolling real slow then almost disappears with speed into higher pitches.
Any ideas?
Any ideas?
#57
hummermongolia
10-04-2015 07:55 PM
kimhien
01-14-2013 09:12 AM
Alex2012
10-01-2012 01:53 PM
Ken Marsh
05-15-2011 11:41 AM
