2003 Hummer H2 sunroof leak!
Old 04-08-2016 | 01:13 PM
Wfive's Avatar
Default 2003 Hummer H2 sunroof leak!
Anyone have any pointers on sealing up a sunroof?
I assumed it was marker lights and siliconed them. But after a normal rain I still get tons of water pouring down on me when I go to drive away.
It drips down from left and right handles and around headliner around sunroof.
Do I need to remove the whole headliner to seal up? Or worse the sunroof?
Old 04-08-2016 | 02:27 PM
madmayo's Avatar
The drains are most likely plugged. You need to get up there and try pouring some water down them and see if the water evacuates. If not you will either have to find something you can push through to get the debris out or use an air compressor.
Old 04-09-2016 | 12:01 AM
johnnyreno's Avatar
or run a bead of clear silicone along the black metal strip against window and body windshield that's around the window top and bottom seam to leak stopped mine
Old 04-09-2016 | 12:03 AM
johnnyreno's Avatar
no its the windshield prolly leaking
Old 04-10-2016 | 12:02 PM
Wfive's Avatar
DRAINS? Where are those? Can you snap a photo?
Old 04-10-2016 | 04:41 PM
Wfive's Avatar
OK, went to open the sunroof to inspect the drains and found the sunroof has no power to open. I press the button and nothing. I would never open it anyways so is there a way to open manually?
Old 04-27-2016 | 02:51 PM
honda400ex2003's Avatar
i finally blew mine out last night, in hopes of finally getting some electrical gremlins to quit screwing with my heated seats. thats another topic though haha
check around your front top edges of the wind shield,
steve
Trey124
08-07-2013 08:49 AM
6spd04cobra
02-24-2010 11:11 AM
Ghostrider
07-08-2008 03:22 PM
H34 pleasure
44
05-04-2007 04:17 AM
iruffneck
17
03-04-2006 01:33 AM
Quick Reply: 2003 Hummer H2 sunroof leak!
