2003 H2 Air Suspension Help Needed!
Hello All,
I have a 2003 H2 with 117k miles. Today the compressor started running and would not turn off. After several minutes of running I hear a hissing / air pressure release sound and then the compressor continues to run. I looked at both air shocks and they appear to be equally inflated with no noticeable cracks or ruptures.
Is this a symptom of a bad air shock or a sensor or? What should I check for next?
Thank you!
Thank you!
Update
Just back from a business trip and replaced the air shocks. The compressor continued to cycle on/off so I took the H2 to the dealer this afternoon. They hooked the car up to a diagnostic scanner and found a bad relay on the compressor board. Should have that replaced on Monday and have the H2 back on the road!
Unfortunately while at the dealers they found a water pump leak so that will get replaced as well.
calif phil
02-25-2011 01:00 PM
