1999 H1 dies going down the road
ive owned it for about a year havent had many problems but this one has stumped me
when you are driving down the road it feels like its running out of fuel then it shuts off it fires right back up then drives again no problem then loss of power and dies again changed fuel filter and i noticed one of the injectors is leaking just a little any advice thanks
Might want to check you fuel filter (open drain and see if you get some h20 out) I've put inexpensive prefilters in my H1's you never know when you'll get some fuel with some rain or condensation in it. It can clog the filter just enough to starve the engine but when you shut the fuel pump of and think about it for a few seconds the h2o and sediments can fall back down into the filter housing waiting to get back into the filter again. That it starts up again kinda supports it's not completely out of fuel because you would probably have to crack and injector or two to get it running again. I like the cheap prefilters (eg Napa or such) much cheaper and easier to find than factory filters.
sorry I missed you changed the filter- depending on what you might have been doing and where you have obtained fuel it's really common when the rainy season is upon us that you can get a significant amout of water into your fuel tank, You might want to take you old filter and put it into alittle bit of clean fuel and shake it around and see if you get some water separating out if so you may have to either keep feeding it filters or drain the tanks.
Had my lift pump go bad and would hydrolock when it got too hot. And I had a air in fuel system issue that haunted me for two years. Ended up being a small pin size hole in my pick up tube in my tank. Kept it on full and the problem went away.
mbh307
02-17-2010 07:29 AM
importkiller
03-02-2008 12:01 PM
