07 transfer case fill
Old 11-21-2011 | 08:14 PM
jasons38506's Avatar
Default 07 transfer case fill
My vin number is 5GTDN13EX78201456. I was wondering if I have the issue with the transfer case filling procedure? The X in my vin is throwing me when I compare it to the vin range I have seen online.
Old 11-21-2011 | 10:53 PM
This is the only info I have tagged for the T-case fluid VIN #s:
ONLY for 2006 and very early 2007 with a vin prior to 5GTDN13E778100102.
Your VIN is past the 100102 so it look like you fill to the normal service level.
Old 11-22-2011 | 09:16 AM
2wheelmonster's Avatar
I would agree, also you could measure how much you drain out and then based on your mileage you should have a good idea on how much to put back into the transfer case.
Old 11-22-2011 | 09:50 PM
rsc's Avatar
rsc
after the quickie lube guys pulled the fill plugs to check the condition of fluids during the last oil change I had to add the 8oz again. I found that filling to the fill port as normal on level ground and then backing the rear of the Hummer up on an incline or curb that I could add the extra fluid through the fill port without having to pull the speed sensor. I also used a paint pen and wrote a nasty-gram by the fill port so they "might" have better sense than to pull the plug again.
bowtieturninghummerguy?
01-06-2012 03:15 PM
OingoBoingo
02-03-2009 11:29 AM
cnynctry
03-06-2008 10:33 AM
vger105
20
12-31-2007 02:51 PM
machines
03-01-2007 08:21 AM
