06 h3 help on tire size
Old 01-20-2012, 09:36 AM
Bunger's Avatar
Originally Posted by SundownAudioNY
Some 16" wheels will have brake caliper clearance issues but some 16" wheels will work with the Rancho kit.
You're right. The OEM 16" wheels will have a problem.
Old 01-20-2012, 09:45 AM
SundownAudioNY's Avatar
You can get away using the factory 16" wheels but it would require a minimum of a 1.5" wheel spacer to get the correct backspacing in order to clear the UCA and steering knuckle. Here is Chris/06H3 rig with a Rancho lift and 1.5" hub centric to wheel centric spacers.
There is also a Rancho lifted H3 from CZ with 2" wheel spacers and stock wheels. Pretty sure he is a registered user on this forum (Allroadshop?).
Old 01-20-2012, 02:36 PM
I'm pretty sure he is buying 1.75" spacers. The 1.5" spacers he has now puts the tires sidewall way to close (less than 1/8") to the Bolt head on the upper A-arm. So to be safe, go with a 1.75" spacer to keep the OEM wheels with a Rancho lift!
Old 01-20-2012, 02:59 PM
I agree but it depends on the tire size. If you plan on going with a 12.5" wide tire, I would play it safe and go with a 1.75". He does plan on swapping them out with 1.75" spacers but his old spacers will work perfect with my pizza cutters (10.5's) .
Andreas_Sweden
02-02-2013 09:03 AM
Hummer79
01-07-2013 11:28 PM
davyo
12-06-2012 11:27 AM
IN2deep
10-15-2007 09:23 PM
davyo
08-02-2006 07:04 AM
Quick Reply: 06 h3 help on tire size
