04 H2 won't start
04 H2 won't start
Hello everyone,
My 2004 H2 won't start. Battery is good, all power equipment works, trans. will shift to all positions, key is not getting stuck. It just won't start, I turn the key, and everythings seems to work as it should, except when I turn the key to the start position, nothing. No noise at all. Can someone please help? I used the search, but couldn't find any help.
Seriously? Its an automatic transmission...your not going to rotate the engine by pulling the vehicle in any gear.
If your not hearing any noise, I'd look at the starter relay. If you see another relay w the same part number on it, just swap them and see if it starts.
I also used a code reader, and there are no codes showing up. I know others have had similar issues, but can't find any info. Probably gonna have it towed to the dealer, but I am pretty far from the dealer. This is the first time this happened. I know other have reported hit and miss issues like this. If I could just get it going I would drive straight to the shop.
I am not sure what the "starter motor" is. do you mean the starter solenoid on the side of the starter, the starter itelf, or something different?
