Upgrading Rear Speakers H3T 6.9 adapters?
Ok so I pulled my rear speakers out 6.9's to replace the original speakers and factory speakers have the adapter built into the speakers. Is there a adapter made by a company that supports a direct replacement?
Or do I need to find a universal 6.9 adapter and modifiy my install to fit properly? Thanks Mates
I have the monsoon system. I upgraded my radio to a alpine car play system. I replaced the front door speakers with some rocksford 6.5 punch (pps4-6 mids) and was going to replace the rear doors with some rocksford T1693 but I stumbled across 2 issues the 4 wire plugs and the housing still attached. I read around about cutting the housing out with a Dremel. Would you recommend replacing the amp as well. I will replace the tweeters as well but after researching looks like I will need some bass blockers for new tweeters.
The Monsoon system in the H3T is much different than the H3.
The rear speakers use the larger 6x8" speaker as a sub-woofer. Therefore it only receives that bandwidth of the audio signal and are separately amplified from the 3" Mid/Tweet.
You will need to procure a 6x8 or 6x9 separates/component set that has an external crossover like the example below. The Mid/High frequency speaker wires from the Monsoon will go to the external crossover input, then from the tweeter output to the tweeter. (this is because the Mid/High frequency from the Monsoon amp will fry a tweeter. The Monsoon amp crossover point for the rear mid/high has too much mid for a normal 1" tweeter)
The Low/Sub frequency speaker wires from the Monsoon will go directly to the woofer.
The low pass side of the external crossover will remain unused. The Monsoon amp already has a crossover for the low pass.
There are 4 wires going to the rear speakers with the monsoon system, conduct a continuity test on the main speaker's wire, and the other end to the amp.6x9 reusing the old speaker mount.
Or you can return them and buy component 6x9s as I mentioned above.
If you think about taking the JJ advise above. He has no Monsoon components remaining. He no longer uses the amp or head unit and he is STILL using a separate passive crossover set I mention above.
Easiest way, I guess would be to remove the radio and look at what adapter the PO used to install the new radio. Look up that # and see if the adapter is for base or Monsoon.
I removed the H3T Monsoon Amp and replaced it with an H3 amp and added a sub-woofer (under the rear seat) with the sub channels of the H3 Monsoon Sub.
I run MB Quart Old School Competition 8" separates in the front doors and MB Quart Old School Q Series 8" separates in rear doors (note: some cutting is required to do this mod).
NOTE: I only used the cheap Scotch Lock comnnectors for testing. Everything was stripped, soldered, heat shrunk and aircraft laced for the final installation.
chasekanter
12-12-2012 11:32 AM
Bdawk20x
05-18-2010 12:52 PM
