Missing Rancho bump stop bracket?
2009 Hummer H3T Adventure
Hey guys, I was looking at the Rancho kit pdf. and noticed I do not have the rear bump stop brackets. Is this a big deal or a reason this wasn't installed? I obviously can't replace it so any help is appreciated, thank you.
Simple math:
1-Measure the distance between the bottom of the jounce bumper to the bump stop plate on the axle.
2-Measure the shock travel distance when fully compressed.
Very simple fix,
Local steel supplier, purchase some 3x4x1/4 tubing cut to 6"( you will need 2, and drop will work and is cheaper).
Drill holes for fasteners.
Prime and paint (your color choice), then install.
Synthetickiller
07-31-2015 10:31 AM
quadblaster240
04-28-2012 09:29 PM
