L Turn Signal
Old 05-29-2011 | 08:45 PM
RaYoSeKiZ's Avatar
Default L Turn Signal
08 H3 L turn signal not working, I want to try changing the bulb myself but donno how to. Any help from you guys...
Thanks a lot
Old 05-30-2011 | 09:30 AM
Autobot85's Avatar
Front or Rear?
Old 05-30-2011 | 06:48 PM
08JJ's Avatar
Open the swing-gate to remove screws. Remove the two screws form the tail lamp case. Remove the case and turn the bulb socket counter-clockwise to remove bulb.
Old 05-30-2011 | 08:42 PM
RaYoSeKiZ's Avatar
Originally Posted by Autobot85
Front or Rear?
FRONT
Old 05-30-2011 | 08:44 PM
RaYoSeKiZ's Avatar
it's the front but thanks for the info at least I know what to do in case..
Old 05-31-2011 | 08:09 AM
Autobot85's Avatar
For the front, you will have to remove the grill, and also the headlight assembly.
There are 6 bolts you have to remove to get the grill off. Pop the hood, and you'll find 4 of the bolts. 2 in the center, and 1 on the far left, and far right of the grill. the other 2 bolts you will likely need a ratchet extension to get to. they are in 2 of the slots on the grill. Once you get all the bolts out, just pull the grill off (it's still being held in by some clips). It should just pop off. Once you have the grill off, you will need to remove the headlight assembly. It can be a little difficult, but overall it's pretty straight forward. I believe there are 4-6 bolts holding each assembly in. The hardest one to get to is underneath the assembly.
While you're replacing the one bulb, you may as well save yourself some time in the future and replace both sides, or upgrade to LED's.
Hope this helps
Old 05-31-2011 | 09:15 AM
08JJ's Avatar
Holy Crap:
HEADLAMP ASSEMBLY, HEADLAMP CAPSULE AND PARK AND TURN SIGNAL LAMP REPLACEMENT
General
06-07-2010 09:28 PM
ludwig75
02-01-2009 04:02 PM
AMG55
19
01-11-2008 11:03 PM
thehammer12
07-06-2007 11:19 AM
h3carlos
01-16-2007 10:09 PM
