Bluetooth issues?
Yep, didn't think it was but just wanted to make sure, check out any and all ideas so to speak before heading to the dealer especially since they are about 89 miles or so one way, lol. I also was hoping someone else reading might have had a similar problem if mine wasn't related to the above issue. Thanks.
My T also had pairing issues (resolved) and it also has flashed the tire pressure warning. Also, one day my Transfer Case lights signaled it was in the neutral position....while driving!! So, dealer replaced servo motor that controls the T/C... (resolved). Like you, I consider it teething pains 'cause my old H3 was perfect. LUV MY T. Drives like a Caddy!
My BlueTooth is pretty lame, half the time the other person can't hear me and it also gets really glitchy when paired with my BlackBerry phone... I don't know why but it garbles the voice commands from the phone; a typical call goes like this:
Me: *Activates voice dialing on phone when paired with BlueTooth*
Phone "Say a Command"
Me "Call John Smith"
Phone "Did you say call [insert screeching fuzz]"
Me ".... Yes?"
Phone "dialing [insert screeching fuzz]"
Bob: "Hello"
Me: "Ahhh Sorry, I was trying to call somebody else"
Bob: "hello, is anybody there?"
Anyway, you get the point. I have pretty much stopped using it all together now.
Me ".... Yes?"
Bob: "Hello"
Bluetooth problems in '09 H3
I came onto this forum and found what I was hoping to be a fix! Reading more on the forum tells me I need to take My H3 back to the dealer to try again! Crossing fingers cause this is really a pain in the a$$!! I am having the same problem as many of you with the pairing issue!
Mine worked flawlessly for a few months and then would not retain the pairing. I took the bulletin info to the dealer and supposedly it was fixed with the updated software.
Fact is, the headset I use works better and is private in the event you have someone else in the vehicle. My issue with the GM hands free is that it overrides other systems already in use.
Here is the scenario I have dealt with. Get into the vehicle with a passenger and put a bluetooth device in your ear which is active with your phone. If you get an incoming call, the GM device overrides the earpiece even though the earpiece was connected first. Now your conversation has to be public.
SlinkTMP
12-21-2012 10:21 AM
IgottaH3
01-07-2007 01:01 PM
davyo
10-26-2006 02:16 PM
crc2k
07-13-2006 12:35 AM
