Wooohooo that engine noise ??
2006 H3 150k miles
Sounds even worse on video , appears to be coming from just under the oil cap / plastic cover . Any thoughts . Still runs great and idles well?
is it ready to go boom ?
Just changed the oil / filter , no change.
Does it at start up when cold continues 1/2hr later when up to temp, doesn’t go away .
i also noticed with the belt off the new Power steering pump if I grab the pully , the shaft moves in and out 1/8 of an inch , the pully is secure on the shaft though. is It normal to move that much ? at the end of he movement there is s tap or bang.
I had similar sound on mine and it was the water pump. Looks like you're diagnosing the issue though. Best of luck.
Famousjunky
10-21-2017 10:56 AM
