windshieldwasher
Old 08-16-2023, 03:19 PM
Originally Posted by mitch1856@485
no my wife held the washer switch down with the key on and i tested the plug going into the front pump
Did you test connector at the rear pump or swap the lines until you get a roundtoit?
  #22
Old 08-22-2023, 10:01 AM
650Hawk's Avatar
Which pump are you checking?
If you are checking the pump at the front of the washer fluid tank, of course it won't have power when your wife holds the switch for the front washer. That's because that pump is actually the rear washer pump. The pump for the front windshield is at the rear of the tank. Look at the pic that Hummerz posted above.
  #23
Old 08-22-2023, 10:56 AM
mitch1856@485's Avatar
yes i have washer in the front by pushing the rear washer thanks
  #24
Old 08-22-2023, 12:05 PM
Just get a new WINDSHIELD washer pump, (they're cheap) before you pull the tank to check. Check/repair/clean connector, empty clean tank, and replace pump. If pump still good, keep for backup. In the meantime you will need to keep the washer fluid at a higher level. Btw, I don't use my rear window washer:
oceanbrave
11-10-2022 04:04 PM
JerseyJoe
07-20-2017 12:08 PM
Roadstarr
05-29-2013 10:21 PM
PhenyxH3
02-03-2011 08:20 AM
J.W.
01-24-2011 12:27 PM
Quick Reply: windshieldwasher
