Winch mount plate
Your rite and wrong about this. The reason the CBP shelf plate is so strong is based on construction and the material used. It uses 5/16" steel where the other use 1/4" and 3/16" plate. When using the thinner plates the mount will flex more allowing lateral stress on the front frame plates making them bend. Has nothing to do with the location of the fairlead. If the impact bar is torqued on rite the frame will bend with any of these systems if the winch is not used properly or the winch is too big.
My experience is that when the winch is buried winching on the front is generally useless. In that case you usually need to back up and winching forward only makes matters worst. If my winch is buried, I'll get out the Hi Lift jack and use it to winch either the front or the back. It might take a little longer but I won't break my vehicle.
Interesting point, but not supported by Engineering principles. The winch line load is the force and the distance from the fairlead to the frame is the moment arm. The product of the load and the moment arm determines the torque that is applied to the frame. The thickness of the plate only effects the loads in the mount plate and it's subsequent distortion. It doesn't change the torque that is applied to the frame. It doesn't make any difference how stiff the plate is, the torque is still applied to the frame and that is the weakest link. You need to increase the strength and stiffness of the frame not just the connection. The lateral loads are not that big of an issue because the winch is mounted between the frame rails laterally.
True enough. Access to the winch with the DeFelice bumper is restrictive, but the most important point is the structural integrity of the winch mount. Access and ease of use are secondary. I wanted to maintain the approach angle of my vehicle and since I only use my winch in emergencies, access was third on the list.
Access and ease of use should not be secondary especially in emergencies when you need to get hooked up and set fast. The CBP shelf mount takes zero approach angle away.
Your rite about the winch being useless when it buried. Good reason to have a highmount shelf winch. And you can winch yourself out backwards from the front. Maybe not so easy with the hidden winch since the fairlead is rite on the front of the H3. Damage to the body may be hard to avoid if you need to winch out backwards. Hooking your line to a pully off to the side is a lot easier with a highmount shelf winch because the fairlead is out in front of the H3 allowing you to tie off 180+ degrees to either side with your rigging.
No hard feelings, I like this conversation. Too bad more people are not reading it.
That was simple short question and now we have great discussion
Many good information. But i have one small problem in Poland in not allowed to drive on road's with sharp object's "sticking out" from car shape.
For now i'm looking for more information about this.
That sucks! Looks like your going to have to get a hidden winch system or a BA bumper.
Circuitguy
10-28-2014 10:19 AM
helium3
05-11-2013 03:01 AM
parishh3guy
07-31-2007 06:39 AM
CruisinCarAudio
04-03-2006 04:07 AM
