Transmission Cooler
Old 02-19-2012, 08:53 AM
CHP's Avatar
CHP
CHP is offline
Originally Posted by 2wheelmonster
I think one question is: what is the real benefit of this besides using the one intregated in the radiator? Better performance, cheaper repair down the road? and how long do you plan on keeping your H3? because any upgrades/new parts are going to last a while. I have 65k on mine and the only thing I've replaced is all the fluids everywhere and the vehicle is totally different. Smoother, less vibration it feels like. I guess it's all in the eyes of the beholder.... good luck
There were two reasons why I put in a separate tranny cooler: 1) with the stock radiator some people had the coolant mix with the tranny fluid and ruin their transmission (this happens on other vehicles too like Cadillacs), 2) I had to change the radiator and will probably have to change it again in another 40-50K miles and this mod makes it easier.
On the opposite side, the tranny fluid heats up slower and may not reach as high of a temperature as with the stock system. For me it takes a little longer for the torque converter to lock up when its really cold out. My tranny fluid probably will not reach 170-180 F during my normal drive.
Old 02-19-2012, 10:25 AM
drtom's Avatar
Banned
[QUOTE][My tranny fluid probably will not reach 170-180 F during my normal drive/QUOTE]
now we need to find out how this affects tranny life!!
what is the design temp of auto trans??
one benefit may cancel another?
Old 02-19-2012, 05:44 PM
DCB-270's Avatar
We just bought our H3. Is there a way to tell if the radiator has been replaced?
Old 02-20-2012, 05:39 PM
CHP's Avatar
CHP
CHP is offline
One of the problems with top plastic tank on the original design was that it could contact the top center of the rad support. The design of the new radiator has the upper tank shifted to the rear more to create clearance to the rear edge of the rad support.
You might have to search for pictures showing the original design and the slice worn into the top tank.
Perhaps someone can explain this more clearly for you than me.
Old 02-20-2012, 06:59 PM
DCB-270's Avatar
Thanks CHP. After reading the trans temps with the stock setup on link you provided I just ordered the Hayden 405. It gets real hot here and heat will kill a tranny. We also tow short distances. Not to mention if the radiator fails and I get anti freeze in the tranny.
Old 02-21-2012, 12:05 AM
When I get past the "magic" 50K mark, I will be installing either the B&M or the Flex-a-lite below and bypassing the OEM radiator all together. I am going with a cooler/fan combo due to the lack of air flow when wheeling plus the BA bumper/Winch upfront blocks even more air flow and the mounting locations are endless.
B&M Hi-Tek Automatic Transmission Cooling System 13-1/2"x9"x3-1/2" with 9-1/2" diameter fan:
Hi-Tek Automatic Transmission Cooling System 13-1/2″x9″x3-1/2″ with 9-1/2″ diameter fan | B&M Racing & Performance Products
Flex-a-Lite #45951 Shrouded HD Remote Oil Cooler:
Remote Mount Cooler/Fans
Old 02-21-2012, 03:04 PM
DCB-270's Avatar
Thise look nice for whelling. We mostly run down the highway so I think that other will be ok for me.
mb7050
10-15-2010 01:24 PM
Rob4092xx
08-08-2009 08:04 AM
josh1899
08-13-2008 08:48 PM
mastercraft88
03-23-2008 01:20 PM
anthony42376
05-21-2007 11:59 PM
Quick Reply: Transmission Cooler
