Is there a bearing in the t-case output shaft seal
Old 07-22-2021 | 11:41 AM
KevinA's Avatar
Default Is there a bearing in the t-case output shaft seal
I知 looking at photos and videos of the transfer case output shaft rear seal and it looks like the oem part might have a bearing in it. The one I got from autozone does not. Is there supposed to be a bearing in it or not? I知 trying to not find out by removing the seal and having a down truck till finding the part.
if there is, can anyone identify the bearing I need?
any help would be appreciated.
Old 07-22-2021 | 02:28 PM
A seal is a seal, a bearing is a bearing.
#9 (89059495 Supersession(s): 88984500) and #20 (89059515) below are the T Case output "seals" rear and front respectively. #8 is the rear output shaft bushing. Hence, no bearings.
Old 07-22-2021 | 06:14 PM
It's All Ball Bearings Nowadays.
#44(front) is 89059520:
Old 07-22-2021 | 08:35 PM
KevinA's Avatar
[thanks doc. Can稚 believe you池e still here 😅. I was mostly on the hummer x club but remember your postings. I have the number 9 but some photos I see look like it has metallic bearings inside packed w red grease QUOTE=Doc Olds;386566]A seal is a seal, a bearing is a bearing.
[/QUOTE]
flyinghunter
16
04-30-2014 11:55 AM
smileynialley
03-25-2013 05:19 PM
bigstick0000
11-28-2012 10:06 PM
jash3
02-01-2011 08:15 PM
Widespread Hummer
10-24-2010 08:26 AM
Quick Reply: Is there a bearing in the t-case output shaft seal
