temperature gauge not working
Old 12-19-2014 | 11:30 AM
Originally Posted by DMBFan
Did you get the same P0118 code?
Was it a messy swap out for thermostat?
Possible causes for a P0118:
- Low engine coolant level
- Faulty Engine Coolant Temperature (ECT) sensor
- Faulty engine coolant thermostat
- Engine Coolant Temperature (ECT) sensor harness is open or shorted
- Engine Coolant Temperature (ECT) sensor electrical circuit poor connection
Old 12-20-2014 | 08:31 AM
DMBFan's Avatar
Looks like I'll be swapping out a thermostat. .....
Thanks for the info.
Old 12-20-2014 | 12:36 PM
happythree's Avatar
Default t stat??
if you get hot air and no overheating ,the t stat must be ok.
mine heats up in 5-10 minutes with hot air.
Old 07-02-2020 | 12:31 PM
Antonio2020's Avatar
Originally Posted by lilcmtz
im having an on going issue with my temp gauge not working. at times it reads fine but then will all of a sudden quit reading, wich then causes the "ac off" to come on the dash and the ac quits working. what could this b? sensor? faulty temp gauge? please help i have a one year old daughter and it sucks when the ac shuts off while shes with me. i live in texas so its HOT!
did you find the answer?
Old 07-02-2020 | 01:56 PM
Welcome to HF.
Answer to what? This is why you should post a new thread with your question including year, model, miles and any recent work performed or symptoms experienced instead of tacking on the end of a SIX YEAR OLD Thread,
READ: Old Threads/'Necro-Bumping'
Old 07-17-2020 | 01:18 PM
Maureen Barrett's Avatar
Default Temperature Guage quit
I have a 2003 Hummer H2. I put in a new battery and my temperature guage isn't working. It goes up as usual when I start then drops to 160 and stays there. What causes this?
Old 07-17-2020 | 01:32 PM
Holy Krap!
Old 07-17-2020 | 02:18 PM
Welcome to HF.
Maureen..... welcome. I have to say, you have no clue how a forum works do you?????? You dug op and OLD THREAD even after I posted the quote above and provided the link to the request that people avoid NECRO-BUMPING! ..............and, you are asking an H2 question in the H3 section. See, this works like this, any question regarding an H2 GOES IN THE H2 SECTION, not here on the end of an OLD AZZED Thread in the H3 section. Wanna try again? How about asking your question in a brand new Thread in the H2 Section since I am now closing this thread.
Thank you for your anticipated cooperation.
Hummerrican
08-11-2015 09:30 AM
Don Janovyak
07-24-2015 08:01 AM
JensH2
12-14-2013 03:27 PM
usma89
10-14-2013 08:12 PM
RealJeep
30
07-01-2011 10:24 AM
