Roof marker light spacing
Yeah....30 holes total! . Being an engineer, I'm planning this out VERY carefully, but it's STILL taking some psyching up to do!
I'll be able to tell you PRECISELY the amount of time.......after I'm done
Not sure exactly what you mean. If you asking WHERE my connections will go, I'm thinking of running the two outboard light wires down the 'A' pillar exterior moldings, into the engine compartment, and hooking to the parking light harness. The three roof mount, will go under the headliner, down the interior 'A' pillar molding. I will then ground under the i.p., and run the hot wire to the gray wire coming from the headlight switch. I'd sure like to see a pic of your lights in the daytime, maybe an 'overhead' shot that would show location and spacing?
