Replacing sunroof seal
Old 09-13-2019 | 08:24 PM
AKcody49's Avatar
Default Sunroof seal leak
[QUOTE=CWC;313948]I didn't think about taking any photos, but it's pretty straightforward. You can actually see the tough rubber piece that is mounted to the glass frame from underneath when you have the sunshade open and the roof closed. And the replaceable rubber seal around the perimeter comes off really easily, goes back on ok if you use just a little dab of o-ring lube in the channel to re-insert onto the flange of the hard rubber part, (the part that was pulling away on mine). So far, so good. Took it through the car wash with only a drop or two through the seal into the drain tray. It is staying put right up against the metal where it
So what did you end up buying
Old 09-16-2019 | 11:20 AM
Welcome to HF.
This is why we do NOT dig up OLD as dirt threads...... CWC... the guy you are asking a question of, his last activity was 07/18/2014. More that FIVE Years ago!
cavssut
03-09-2015 11:15 AM
CWC
05-26-2014 08:42 AM
TowDawg
12-19-2010 05:18 PM
tony1969
01-22-2008 11:05 AM
anthony42376
04-24-2007 04:36 AM
