Radiator has screw on threaded inlet/outlet transmission cooling lines
Old 09-20-2019 | 09:37 AM
Joel Cunningham's Avatar
Exclamation Radiator has screw on threaded inlet/outlet transmission cooling lines
this is what came from amazon as an exact fit:
quick connect
This is what was on it
original radiator connection (screw on)
I am trying to build a connector for this.. has anyone seen the screw in connection before??
thx
jbc
Old 09-20-2019 | 09:51 AM
Happy Hummer's Avatar
Well, that's interesting... The top one is factory style the bottom I've not personally come across.
Both 06 & 07 use/d top picture style fitting. I've replaced a couple times and read a lot of threads but not seen the screw on type.
Old 09-20-2019 | 10:03 AM
thank you for your thooughts!!
Old 09-20-2019 | 10:42 AM
Alpha X's Avatar
You should show us what the transmission lines that connect to this look like.
Old 09-20-2019 | 03:32 PM
The top photo is your standard OEM GM "quick connect". Somebody modified the connection in your bottom photo. No doubt somebody that thought the quick connect was just a nut, which it is NOT. Many a novice has messed up their radiator when unscrewing the quick connect.
Matt Pratt
07-15-2020 11:36 AM
CBphoto
09-14-2019 02:45 PM
jryanantczak
11-15-2017 11:42 PM
hmer
03-24-2014 09:19 AM
Songman
03-26-2011 12:55 PM
