Question about leveling
Old 09-22-2020 | 08:40 PM
Bruce Weller's Avatar
Default Question about leveling
I know this has been asked a million times but Im working on getting some new tires and wheels..and going to level my vehicle.. Is it fine to just turn the bolts 2 turns I believe is what I was read on each side.. and thats it? how will that differ in ride> or should I go with the leveling kit and if so I also see some kits come with shocks.. is this necessary to replace the shocks.. does it all matter? I dont take my H3 off road ever... but I want to do the right thing.. Thanks Bruce
Old 09-23-2020 | 10:12 AM
Welcome.
OK so you know there are a bazillion threads on this topic, but did you read any?
Why bother if you are not going to wheel it, just leave it nosed raked for fuel efficiency.
Leveling kit = NO, NEVER!
Make sure not to exceed 23.4" fender lip to hub center after adjusting the T Bar Bolts. The position of your T Bar has zero effect on spring rate. Get an alignment done after changing adjusting the T Bar front height.
You do not "need" new shock, bump stops, or anything other than an alignment.
Old 09-24-2020 | 02:10 AM
Thank you Doc for answering my question I read all the related topics and from what I got out of this is dont waste your money on buying the leveling kit its not needed.. better to buy the better dampening shocks then adjust the T bars.. and important to get it aligned afterwards.. is this correct.. the shocks the others recommended are these
The correct front Bilstein shock number if doing a Torsion lift is F4-BE5-C153-HO. The proper rear Bilstein part number is F4-B46-1698-HO for stock height rear ends.
so this is what Ill do.. correct.. only thing is ..how hard is it to change the shocks front and rear.. so these are a great shock to buy... can I do it myself.. any tricks or hints I need to know.. Ill order the shocks tomarrow.... Thanks so much again.. Bruce
Old 09-24-2020 | 03:26 PM
Nope, I would not buy the Bilstein Shocks, many many of them start leaking way too soon. You do not need any new shocks. I would recommend the ACDelco OEM Adventure model shocks. I have Old Man Emu Nitro Chargers, even better. Do a search here on shocks.
Shock swaps on an H3 are very easy DIY projects. On a scale of 1-10, about a 2.5. There are how to vids on the web, some threads here too.
Old 09-27-2020 | 03:26 AM
Well Im glad to hear its an easy do it your self project.. but Im still confused.. I wont go with the Bilstein shocks but you say I dont need new shocks but I recomment the AC Delco Adventure model Shocks..
Old 09-28-2020 | 09:02 AM
Just because you raise the front via T Bar adjustment does not require anything but turning the T Bar Key Bolts and an alignment. Does not require new shocks = do NOT "need" new shocks.
If for whatever reason (age, miles, time of day, boredeum, pissed at the wife etc...), you want to replace your current shocks, I would not recommend the Bilsteins... my opinion after seeing many put on H3s only to live a short life before need of replacement.
IMHO the best shocks for the H3 are the OEM ACDelco shocks that come on the Adventure package, or OME Nitrochargers.
Old 09-28-2020 | 09:41 AM
X2! It will ride like it did from the factory with the OEM Adventure shocks (good ride), It will ride like a dream on the Old Man Emu Nitrochargers (on and offroad).
ockie
H3 Frequently Asked Questions
37
03-13-2015 10:11 AM
TMB
08-28-2014 10:23 PM
joebot8484
18
08-19-2010 09:22 AM
asvinci
12-03-2008 05:31 PM
dilo2001gt
21
12-06-2006 09:40 PM
Quick Reply: Question about leveling
