Power Steering Leak, Led to ODD FINDING
I had a power steering wine so I filled it and thought nothing of it. 3 days later, get the wine. So I started deducing culprits and found a pipe/hose resting against the oil pan. It was significantly oil soaked location either power steering fluid or oil I don’t know yet. At least not for sure. Looks like oil line from power steering pump? But the hose goes to the ps pump.
anyway.
well I think that groove wore through the line.
I need to know what that line hose is?
You can see the groove won’t in play the pipe/hose I believe the pipe has a worn hole.
anyway I can’t drive it right now as it’s a spurter
Any ideas you guys might have would be great. Guessing I need to just replace this pipe/hose and keep it from abrasion better than the last guy.
It does come from the bottom of the PS pump
thanks guys.
anyway.
thanks guys.
I haven’t seen a hole in the oil pan. I need to get a scope cam in there to see if there is any pin hole.
is this hose a high pressure return hose?
trying to figure which hose to buy.
and yes I will make sure it’s not capable of rubbing on the oil pan.
CarlosC
10-28-2013 03:19 PM
