Pcv valve
Pcv valve
Hi, I bought an 07 h3 3.7L 150,000 mi on the clock.
removed intake airbox to clean throttle body and noticed oil at the rear of the valve cover. All my research tells me it's the pcv valve. So my question is, should I replace the valve cover now or do I have time before the worst?
Already did that, cleaned the throttle body, MAF, air intake box, replaced the spark plugs, changed the pcv valve rubber hose, changed the engine oil, changed the air filter and topped off the engine coolant. Coolant was low. I won't know if that fixed it until I'm able to look inside the air box again
