Oil leak after drive
Hey guys, good news, my transfer case fixed pretty affordably and it is driving nice! I took my son to a campout which was about 50 mins away down the interstate. Made it there and back fine, but woke up this morning to a nice little puddle beneath my front end. It appears something is dripping then running down the skid plate the bigger puddle is on the side my driveway slopes. I tried looking around with a flash light, and could not quite pin point the source. I did suspect the oil filter as it looked a little wet, but I did not see any evidence of a an oil trail under that drain ramp part. Any thoughts?
New development. Took the skids off and found a couple of loose bolts. I am ashamed to ask, but what are these bolts holding on? I tightened the large one, but the two smaller ones seem to just spin freely. Any chance that could have been the source of the leak?
well that looks like a butch job on the oil pan lol! You can see the gray RTV all over the area squeezed out and smeared. Those bolts should be double checked to make certain that who ever did that monkey d!ck routine did not stripped out the aluminum threads. Check the trans lines also for leaks.
Might be talking to myself here, but I dove around a bit and found that the oil is coming from behind this main pulley. The more I look at it, I am thinking all this grey silicone is not supposed to be there and that someone did it to suppress the leak.
Thoughts?
Thoughts?
You have a leak cause by a mechanical issue (ie all the oil pan bolts are supposed to be Torqued: 18 lb ft sides, 89 lb in) stop leak is no going to fix that. I see replacement bolts meaning an incompetent idiot stripped out OEM fasteners and tried to use larger replacement bolts.
