O2 sensor recommendation
Obvious correct answer = ACDelco.
Easy stuff first. Change the sensor and while you are there, inspect the wire harness to it, connecter should be sprayed with electronic cleaner before plugging in the new one, and look at the heat shield for a rattle.
Could be a bigger or different problem, but rule out the sensor first.
Check for an exhaust leak using soapy water and low pressure air into the tailpipe to find the leak. For an exhaust leak the hose into the tailpipe with air, sealed with shop towels, then soapy water would be sprayed around seals, seems, and bosses.
if your hearing rattling noises the catalytic converter is probably breaking apart internally and the sensors are probably fine. if you can get an inspection camera through the first oxygen sensor hole you might be able to see if the cat is damaged. they do sell oxygen sensor spacers for the rear o2 sensors that will trick the ECU into compliance but it will do nothing for a clogged catalytic.
New member. I been an owner of a 08 H3 Alpha for a few years. Love the truck and it's been pretty good. I do think the previous owners neglected maintenance on it but, now I'm getting around to it. Posts I've read have been helpful so will continue to be frequent the forums.
2005H2
12-14-2016 06:07 PM
C31322
09-11-2013 03:27 PM
Kimmea
08-01-2012 07:47 PM
