New tires....315-75R16
Just had these put on the other day...Goodyear Duratracs 315-75R16
Good choice! I have the same tires. Your truck looks good!
those dont look like they stick out as much as mine. what is your offset on your rims?
I dont have a clue...they are factory rims with a t-bar crank
I think it's the angle of his pics. I'm sure you would see them stick out if he had a head on pic.
ya, youre probably right
nice!
i went from 265 in my o7 to 285 but those make me look itty bity
btw, hummers in general look legitimatly good with all rubber ive seen, xcept those flat tires on some"show cars", but i saw a jacked f 150 with smallish rubber and it looked,,krapola,just cheap for a big truck
getting this size soon for my wife's H3 in a kuhmo or nitto dune grappler, any issues with rubbing with the level?
Nitto makes a great tire but each design has it's own use. Terra Grapplers are the best general AT type tire and Trail Grapplers are a more aggressive tire with similar looks as the Dune Grappler.
If you put 35's on the stock rims you're going to have rubbing at full lock, which will actually increase once you level the truck. After market rims have different offsets, which will alleviate the rubbing by having the tire stick out further.
