Looking to upgrade my air intake
Old 01-18-2012, 02:18 PM
2 AirDocs here! But his T-shirts don't come in Double fat I guess?
Old 01-31-2012, 07:00 PM
mattp_160's Avatar
Just installed my AirDoc yesterday. I could tell right away that it was in. Throttle was so much smoother and better going up hills.
Old 01-31-2012, 08:31 PM
58Bisc's Avatar
The outside temp went up to 40 on Sunday and it was sunny, so I installed the AirDoc's intake and K&N filter. I have to tell you that the instructions were the best I have ever used and I write technical "how to's" for a living (well at least part of my day job).
I could only find two minor issues with them. One I needed a philips head screw driver and it was not listed on the tools sheet (I know, I'm nit picking) and I found it way easier to drill the screw hole while I had the box out and the sleeve was not installed. I could just drill all the way through it without worrying about cutting into the sleeve. I then installed the sleeve, then box, then the screw in the hole I drilled.
Everything went exactly as instructed and it was a very quick and clean install. Engine had a different, cleaner sound to it. Now I'm going to have to schedule the PCM upgrade to take full advantage of the all of the upgrades I have done.
Has anyone done a 1 inch body lift with an aftermarket intake was installed? Wondering if it needs any modifications or adjustments...
Old 02-01-2012, 10:08 AM
Songman's Avatar
Does anyone experience more engine vibration with the AirDoc? I have the solid silicone like connectors on my system and they seem to add a lot more vibration to the truck. Is this normal? I'll update to the AirDoc one of these days but just wondering if that would be the same.
Old 02-01-2012, 03:25 PM
This is a good question about a little discussed (or thought out) issue with any body lift.
If you would like to start a new thread on this topic... basically something along the lines of what I made bold above, I will give you some info without high jacking the OP's thread. Others can pitch in as well.
Old 02-01-2012, 03:43 PM
Bunger's Avatar
I'll start that thread Doc. I'm interested as well.
tomsbeast87
06-03-2011 08:03 PM
Luigi
08-28-2010 05:30 PM
mastercraft88
01-23-2010 09:37 PM
provenceman
02-09-2009 10:51 AM
BMJM100
01-10-2009 02:46 PM
Quick Reply: Looking to upgrade my air intake
