Leaking Transmission Line Quick Connect at Radiator
07 H3 with 190,000 miles. Replaced the radiator at 94,000. Now one of the transmission line quick connects at the radiator is leaking just enough to be annoying. It doesn't leak when running, but pushes a couple drops out on startup. if I push the line in towards the radiator while running, it starts leaking. When I pull out on it, the leak stops. Is there an o-ring or seal in the quick connect that needs to be replaced? Any advice on how to stop the leak?
Thanks,
Mark
Thanks,
Mark
When I replaced my radiator recently, the first clip went in easily, I fought the second one for at least 20 minutes. They have to be lined up in the correct orientation, and it's not perfectly obvious which way that is, until it actually clicks into place.
lvu
24
02-14-2014 04:01 PM
CHP
02-05-2012 05:13 PM
