Key stuck in ignition
my husband checked out the steering wheel around the ignition switch and found out it is the ignition switch lock solenoid (see pic). He took it out and the key comes out. Does anyone know the purpose of this solenoid because after he took it off he was able to drive it without it.
make sure the h2 is in park or neutral and make sure there are no broken wires on the shifter in the center console. the wires move when you shift and break
Fixed mine
H3 2008 stuck key.....the issue is when u push the button on the shifter handle a sleeve slides up and down the handle shift when the handle is in park and the sleeve is up all the way...keys come out....when it gets stuck and dies not slide up far enuff....keys are stuck if u pop out the leather and come rind lift them up so u can see under.....u can see the sleeve wd4o it a couple times ...press the button and spray some more press the shift button to throughly clean and lubticat thr shift and the sliding sleave....sleeve should now slide qllnthe way up...and keys practically fall out...then positionbthd leather and chrome pressing slightly to click back in to place.... I shot a video i can send ya if you wanna see....
mine
nncanfarelli
08-04-2019 09:27 PM
hummerhonduras
42
09-19-2012 11:49 AM
ezspirit
06-29-2009 07:13 AM
doyleh3
04-02-2008 10:01 PM
