Jeez...my darling Gf's 06 H3 again...Lol!
On further examination your post is some what related to my query.
A further search had all ready been done early this afternoon.
The switch is a seperate part # from the cylinder .
My question will relate to the cylinder and what the likelyhood of this being the issue?
What proceedure would be best to follow in replacing it.
Would you happen to have the procedure for doing the cylinder and / or the cylinder / switch.
The report was read when she got home tonight and tech labels the area of concern as cylinder. May be though he is interchanging switch with cylinder.
Chris
Chris
You will need to key the cylinder if you replace it to match your current key. Either way, the most important things to do:
- Disconnect the negative battery terminal
- Pull the SIR fuse #27
Time .8
Removal procedure
- remove steering column trim covers
- turn the ignition lock cylinder to the accessory (ACC) position
- the ignition lock cylinder access hole is just under the inflatable restraint steering wheel module coil on the right center of the steering column housing
- insert the 90 degree tip of a pick type tool into the ignition lock cylinder access hole
- push down and hold the ignition lick cylinder retaining pin
- remove the ignition lock cylinder by pulling it out of the steering column
- turn the igniton lock cylinder to the acc position
- push the ignition lock cylinder until the ignition lock cylinder retaining pin locks in place
- install the steering column trim covers
Ignition Switch Replacement:
Time 1.0
10minute procedure requires a tech II, 30minute procedure requires no tools.
Believe me, I have seen it all. I remember 1 time the customer complaint was blower inoperative,
I had a tech that checked it out and listed on the RO, 1-control switch, 1- resistor, 1-blower motor, & recheck. I looked at the RO, and told the tech to go back and check it out further and let me know EXACTLY what is needed! He couldn't diagnose properly! Needless to say, that tech's employment with me, was short lived!
If you decide to replace the switch, just make sure to clean/lube the connector! GL
Michel Hotte
17
12-04-2013 02:20 PM
moto.racerx
25
10-30-2010 06:45 AM
