intake+water?
Old 01-22-2012 | 03:19 PM
Mikawave's Avatar
Default intake+water?
will an aftermarket cold air intake have problems treading deep water than the stock intake? i want to upgrade but i plan on offroading a lot and dont wanna risk water being sucked up from a performance intake. thanks.
Old 01-22-2012 | 04:49 PM
1. Stay away from deep water! The BCM is behind the passenger kick panel. VERY LOW!
2. Look into a snorkel (ARB Snorkel is compatible with an AirDoc) if you still plan on going in deep water.
3. Extend ALL of the Driveline Breather hoses to at least hood level (Diffs, Tcase, trans, etc.)
4. Stay away from deep water! The BCM is behind the passenger kick panel.
5. Stay away from deep water! The BCM is behind the passenger kick panel.
Hope this helps!
Old 01-22-2012 | 05:18 PM
Bunger's Avatar
If you are planning to install an intake, do a little research on "open" types like Volant vs. the "closed" types like AirDoc.
Just splashing thru puddles is risky with the open types
Some reading: Air Doc FAQ
Old 01-22-2012 | 07:19 PM
Mikawave's Avatar
ok thanks a lot for the info guys
Old 01-22-2012 | 07:24 PM
talusfan's Avatar
Why would I want to waste all that effort extending my breathers to the hood level when the bcm is behind the passenger kick panel?
Old 01-23-2012 | 07:05 AM
DAGKANA's Avatar
talus why wouldnt you? getting water into the diff is a bad scenario same with trans... you might not even know it, but once things start to bad you'll need to pull them and change fluid or worse get them rebuilt. the BCM is low lying, however if it goes its prob easier to fix than the drivetrain, but not by much, you'll want to pull the carpet and possibly the seats at that point... Moral of the post is... DONT go into water that you dont know the depth too! Let your crazy friend with his all too cool Jeep do it...
Old 01-23-2012 | 12:55 PM
talusfan's Avatar
Sorry Dag that was meant to be sarcastic I agree though, I always let the cocky idiot in the jeep go first. Water is bad for everything
Steelhead
03-12-2019 10:09 AM
Propst72
05-05-2016 06:08 PM
RUSH=H3
12-06-2006 05:10 PM
importkiller
11-11-2006 04:07 AM
dilo2001gt
07-30-2006 12:47 AM
