I'm thinking about leveling my H3
Well a shop in town is gonna do it for $25... Sounds like a deal to me.
I'm gonna ask for 23'' from the center of hub to the wheel well. After reading through all of the stuff on leveling the front, I heard do not exceed 23.5'' or stuff will wear out faster. So I guess I'll play it safe and go for 23''
But I still have some questions.
What's the general concensus on doing this?
I've read into and I've come to the conclusion that the Blistien Cognito 5100 shocks are the way to go, and then crank the torsion bars. But some of those threads were from 5-6 years ago so I was just wondering if this was still the best way to level the front properly without buying a "leveling kit".
I just want to do it right the first time ya know.
Any advice is greatly appreciated.
Pic of my hummer
Sorry... the HTC One's camera is a poor excuse for a camera..
Pic of my hummer
Did you replace the front shocks? Or did you just turn the keys?
I've been at 23 1/4 for 30k miles and 23 5/8 for another 40k miles. No excessive wear. I ran the stock adventure shocks for most of that with no issues. Raising where the front sits by turning the torsion bars does not change the total amount of travel available. All you do is adjust WHERE inbetween bottomed put and topped out that the suspension will sit at when static. A 1/2" nut under the shock's nut or using longer shocks can give you a hair more travel though before hitting the metal control arm stops.
How much do you pay to have somebody change a residential light bulb? Just wondering as the difficulty factor of adjusting an H3 T Bolt is about the same, except you do have to use a measuring tape to check the height of the front after turning the bolts.
You do not NEED shocks. Adjust the front height to where you want, check it a couple days later, fine tune if necessary. Get a front alignment, then decide if you want to change shocks.
Good stuff, lol.. anyone that can read a tape measure can crank the t-bars..
No, you don't need to replace the shocks (although if original, replace them) however you need to add a spacer to the shock stem or you will end up with a very uncomfortable ride. My a$$ hurts just thinking about it..
Do you think I can pick up the spacers that I need at a local auto parts store?
