H3 won't start (in colder weather) Solutions?
Old 11-07-2011 | 03:01 AM
gotafish's Avatar
Alittle different.Wouldnt start at all. Would crank,but just wouldnt kick in and turn over.
  #22
Old 11-07-2011 | 04:48 PM
Humm3r's Avatar
Gotcha, thanks!
A little update, dealership called tech service and decided it was the whole ignition unit, the wires and the whole sha-bang so they're currently replacing it as we speak and will do tests tomorrow morning to see if it starts.
  #23
Old 04-03-2021 | 07:29 AM
Rayebennett63's Avatar
Default Hard start. Runs for a bit, than idle high and shuts off.
Originally Posted by Humm3r
Hey all you Hummerites,
I got my 2008 H3 about 2 months ago and never had any problems with starting...until it got cooler [mind you not cold, just cool (40 degree weather)] and my H3 won't start, it turns over and makes a little whining noise like it's about to, but nothing.
First, my dad and I replaced the battery thinking it was the obvious solution, but nope. Went out the next morning while it was approx. 50 degrees and it wouldn't start, just turn over and the check engine light and security lock light in the lower right dash corner would come on. Although, my dad came back later in the afternoon when it was about 70-80 degrees and the Hummer would start right up like it never had any problems. I then did some research and found out if could be blown fuses, the ignition switch, battery terminals, or crash mode seats. But why would it start later in the day but not earlier. I've heard that if you come back about 10-30 minutes later it would start due to the anti theft mode, sat in the Hummer for 11 minutes one morning, and the light did NOT go off and wouldn't start. Leads me to ask, is it the cold weather causing something to short or not work properly? Any possible solutions would be greatly appreciated!
P.S.- We took it into the dealership and they claimed to not find anything.
Yeah I've got the same problem with mine I can't figure it out they say it might be the PCM so I'm going to try that next if I disconnect the battery and try it'll turn over and then shut off if I don't disconnect the battery it just won't turn over at all
  #24
Old 04-04-2021 | 10:12 AM
H3Luxembourg's Avatar
You just digged out an 10 years old tread dude.......
  #25
Old 04-05-2021 | 11:55 AM
You have just won the Dig Out That OLD AZZED THREAD AWARD!!!!!
  #26
Old 04-05-2021 | 02:21 PM
Dooooc are you kidding
SquareD
07-01-2024 10:15 AM
chrisg75077@gmail.com
11-01-2019 11:35 AM
ffmf2101
11-19-2018 09:37 AM
yellowhummerh3
05-25-2018 06:48 AM
Big_A
08-15-2015 02:20 AM
