H3 trim plastic clips
I had to replace my third brake light on the h3 and in the process of removing the tailgate trim two of the plastic clips/pins (not sure I’m calling them the right thing) that hold the bottom part of the trim in place broke. The metal clips holding the top piece are fine. Any recommendations on the right thing to order from amazon or elsewhere to replace these?
If you would have asked, you only needed to loosen the top window surround, it need not be removed.
#9 below if that is what you are looking for? Go to any GM on line part supplier and search for rear door trim, use the diagrams to find the PN.
06redhummer
23
07-17-2012 10:32 PM
