H3 Parts Anyone?!?
H3 Parts Anyone?!?
I'm looking for a couple things but the main one is the roof mounted off-road lights, GM doesn't sell them anymore and I can't find anyone that makes them. I need the full kit (not just the lights) including the shroud. I'm also looking for a stock H3 stereo I bought a Kenwood but it might not fit. I need a few other parts too, can anyone point me in the right direction? Or if anyone has a parts Hummer in Niagara, Ontario that would be great.
Replacing the factory stereo is a piece of cake, go to crutchfield, look up what fits for your truck, they will give you part numbers for the proper harness for you vehicle, you can even choose which harness you want, I have the monsoon system with on star etc, but no steering wheel controls, I chose a simpler harness because I did not care if on star worked, but took the one that used the factory sub and amp and replaced the facory warning chimes, if you have the stereo side of your harness its plug and play, you also need to double din adapter. There is a metal piece you need to cut out of the dash. Lots of photos there to help you.
I thought about it but I would have to do some body work and would rather look for the stock shroud instead, I'm going to if I can't find anything though. I guess I could patch the old shroud too.
