H3 Blown Fuse 34 - Help Needed
Hey Guys,
New to the site, looking for some help w/my rig (H3).
My transmission fuse (10A fuse #34 in the fuse box) keeps blowing. Sometimes check engine comes on with P0700 nothing else. Replace the fuse and all good. Dealer cannot seem to figure out why. Wondering if there is a short and where to look/how to diagnose.
With fuse blown, rig has prob switching gears. 10 cents later with a new fuse it is all good.
Appreciate the help!
Transfer Case (switches 4WD to Lock) has nothing to do with the Trans.
One of the causes of a P0700 is a short in transmission control wiring.
How is the Trans fluid level and quality? When was the last time the Trans fluid and filter were changed?
Only a P0700? & Blown #34.As Doc stated, shorted wiring. Check the wiring to the transmission & tcm, could also be a pinched wire inside the pan. Take a close look at the wiring and make sure no aftermarket wiring tapped into that harness. Could also be a short inside the tcm. Btw, I've never seen a P0700 without other codes included.
08+ wiring diagram attached.
That is because you are still trying to use the OEM Battery Terminal Connectors. Take a search around here and you will see that that the first mod to do to every H3/H3T is to replace the crappy OEM Battery Terminal Connectors with a quality aftermarket set like Stingers or your favorite brand.
