Gas Cap Replacement
Old 02-04-2006 | 05:11 PM
crazyfool's Avatar
Default Gas Cap Replacement
I'm switching my H3's OEM gas cap with a stant locking gas cap, and was wondering how to remove the tether from the old cap without cutting it off. I'm hoping to re-use the tether on the new cap.
Old 02-04-2006 | 09:22 PM
dilo2001gt's Avatar
Default RE: Gas Cap Replacement
the easy way is pull the black plastic holder out you can do this with your hands and after take the two tabs squeeze them together and the cap will come out off the holder that waht i did when i put my hummer door on and once your done just push the it back on to the truck .Ihave to remove mine now it going to be differant i want a locking cap to
it very easy
Old 02-05-2006 | 07:04 PM
dilo2001gt's Avatar
Better yet under you wheelwell there are screw tab take a screw drive turn then they pop right out take them out till the top and put you hand in between the plastic and you can do it that way and put the screw tabs back on
Old 02-06-2006 | 11:53 AM
Dennis's Avatar
Here is a LINK on how to install a Fuel door..Amongst other things..Handy..Keep it bookmarked./
Old 02-06-2006 | 04:26 PM
dilo2001gt's Avatar
Dennis i like your link [sm=goodidea.gif]
Old 02-06-2006 | 11:55 PM
dilo2001gt's Avatar
just got my locking cap i know what i be doing tomm.
Old 02-07-2006 | 03:05 PM
dilo2001gt's Avatar
just did mine took two second remove the three tabs under the wheel well unclip it done put the tabs back on
Don't know if i like the cap got to get use to it u turn the key and nothing happens then u play with it then it unlocks[8D]
Old 02-07-2006 | 03:11 PM
Dennis's Avatar
ORIGINAL: dilo2001gt
Kinda sounds like a couple of women I know...LOL
Old 02-07-2006 | 04:36 PM
Raffi76's Avatar
now if I got one that worked like that I would flip out shouldn't cost more then a dollar if it doesnt work properly
Nice instructions but I don't know how I feel about drilling holes in my carito
Old 02-07-2006 | 05:11 PM
Dennis's Avatar
ORIGINAL: Raffi76
The fenders are all polycarb plastic, so drilling a hole or two will not be an issue later with rusting.
