Exhaust Manifold / Heat Shield
I bought my H3 back in the summer and knew it had an exhaust leak at the time. I finally got some time to check it out. I had seen a video where someone had used a shop vac to blow in the exhaust to find leaks so I did that. I was hoping it was just the Oxygen sensor. I started spraying soapy water and it did leak around the sensor. Unfortunately, I found 2 more leaks. Exhaust gasket at #2 cylinder and the manifold is also cracked at end of section coming from #2 cylinder. I'm going to put it back together as I have to use it to drive to work. I was just wondering if it would hurt anything to leave the heat shield off until I replace the manifold. Also, what brand manifold would you recommend I replace it with?
I wouldn't drive without heat shield.
Get your pen and paper ready for a grocery list:
- Magnaflow manifold (if you have extra money to throw away) or
- Walker Ultra manifold (1/2 the price). Note: Either have 2 options, make sure to verify 1 or 2, 02 ports on current manifold.
- Exhaust manifold to head gasket (Mahle or Victor Reinz)
- Exhaust pipe to manifold gasket (Mahle or Victor Reinz)
- Exhaust manifold studs & nuts (8.8-10.9ss)
- Exhaust pipe to manifold studs & nuts (8.8-10.9ss)
- Beer
Why waste money? OP also has a leak at the o2 sensor (G18MM gasket), a leak at the manifold to head gasket, (MAHLE MS19755 gasket) which requires manifold removal for gasket replacement. Check & deck while removed & weld if needed. Replace the manifold bolts, with studs @ 12.9 or 10.9 & nuts, then forget about it, and keep that extra money banked. I could spend $800+ on a new exhaust manifold, however my oe manifold still performs as intended! BTW, I'm down to $185 month out-of-pocket, since purchase, for PURCHASE, MAINTENANCE, & REPAIRS.
Amen bro
Davidf226
11-15-2016 04:34 PM
pepper1
06-01-2012 11:53 PM
