Car loses power when in reverse.... any ideas?
The filter is in the fluid. The seal is not. If the seal is not there the correct volume of fluid will not go through because fluid WILL LEAK back into the pan
And as of running with no filter, good luck with that, thats a good way to cause catastrophic failure to your transmission.
I guess the seal is there to be sure the juice don't sneak around the filter. it gets pulled up thru the filter. it leaks back down thru the filter!! seal or not.
if its not there it just lets a tiny amount of tranny "dust" thru and in time will wear faster. not catastrophic. they are amazingly clean inside after years of use. the pan has a little film on the bottom.
I put "snap"bands in c4 fords years ago at high mileage. not real dirty.
oil filters have a bypass and the engine doesn't blow up immediately!!
it cleans the oil and has nothing to do with pressure. same with the tranny filter.
im going to a tranny shop with some questions and a look at a filter. I think ill buy one and change mine to see just what its all about.
Cashville
06-22-2012 08:16 AM
nyh3peru
08-23-2011 12:16 PM
ecpmd19
03-06-2008 12:41 AM
lindaw
06-30-2007 11:28 PM
