Broken Hood Release Cable - HELP!
Old 03-29-2014 | 04:02 PM
Vikingsfan93's Avatar
Originally Posted by BERULAKIDE
Mine is broken right now too,but if you cant get it open.....
1...Look through the grill on the drivers side and Chase the cable to the latch.
2... feel where the cable hooks to the latch, there is a slot where you can wiggle the cable out of the spot holding it in place.
3....then tug on the cable and it pops like your release in the cab.
4... open as usual with release lever
Hope this helps
That did the trick, thank you very much!
Old 03-29-2014 | 07:22 PM
BERULAKIDE's Avatar
No problem, glad to help. Thats what this place is for, I have saved a bunch of money and time using the info on here and getting help from others. I did figure that One out on my own though.
Old 03-29-2014 | 10:09 PM
happythree's Avatar
the best way to learn is to get a functional h3 and pop the hood and practice.
when your right index finger tip is sore, you got it!
i rarely pull the release anymore
Old 09-17-2014 | 10:55 AM
triximc's Avatar
Sent you an email
Hi, I'm in the same boat as blharty was, with the broken hood release cable, that I'm hoping to replace myself. I have figured out how to get the hood open, but I'm looking for some easy step by step instructions to replace the cable. Any chance I can get that email too?
Thanks for your help!
Old 09-14-2017 | 02:52 PM
Amelia Poitevint's Avatar
Default Broken hood release cable
Suggestions on how to manually pop the Good? The hood release cable is broken and I can't figure out where exactly it goes to release it.
Old 09-14-2017 | 03:11 PM
blharty's Avatar
This posted originally by BERULAKIDE worked perfectly from me. Took like two seconds. Seems to be a common issue with H3's....
Hope this helps
Old 09-14-2017 | 04:07 PM
happythree's Avatar
happythree
Old 03-16-2018 | 11:29 AM
Kalle's Avatar
Default You can open engine hood if cable is broken. See pic.
See Little hole.
Use Screw driver to move clip.
Old 03-16-2018 | 03:35 PM
happythree's Avatar
Old 04-15-2021 | 07:20 PM
David Treminio's Avatar
Hope this helps
I just registered to say THANKYOU so MUCH!!!
