Battery Size/ Replacement
Hi All,
I had my battery replaced today with a 643MF Diehard Gold Battery. I previously had a group 86 Magnaforce...but the car wouldn't start last week. Boosted it, died a couple days later. Boosted again and brought it in, and they thought it was just because my Stinger positive terminal was a little loose. Tightened it and sent me on my way, and it died again today.
Brought it in and they said the charge test said replace battery (it was 3 years old), so had 1/2 the prorated warranty cover the new one (which has a 36 month direct replacement warranty). They didn't have a Group 86 size in and said it was tougher to get as its a "weird" size, so they suggested the 643MF and said it fits in well and is overall a better battery for the truck.
My question is: the 634MF size obviously isnt the same size (or stock fit), but they said it is a beefier battery that would be better for my H3 Alpha. It fits "ok" in the box just the stock cover doesn't clamp down. They seated it under the corners of the stinger terminals, so it holds pretty securely (is just off kilter an inch or so).
Would appreciate any feeedback. Thanks!
I just want to know...does this all sound ok? This new size won't do any damage or cause any problems, moving from the Group 86 right?
hey Hummerz,
Thanks. Yup they secured it down, its in there nice and tight. The battery cover on top doesn't clip up straight but its fine, cables and all are secure.
Thats the exact one except its branded differently in Canada (DIEHARD GOLD 634mf, 690 CCA, 820 CA. They said it is a beefier battery than I had before which is good.
Thanks for confirming!
hey Hummerz,
East Penn Manufacturing | Transportation batteries
curleymon
01-19-2019 10:49 AM
