Air Doc..Does it do anything???
#22
150 buys almost 60 gallons, a 1000miles for me . spread out over the next 500 gal,thats 2mpg. but gone in 1 year so if it did that its worth it, 2 mpg, id buy.
a small unmeasurable increase in power is completly useless so you got to look at mileage. if no definet mpg then its a "platinum hyperdynaflectoriod" that claims 20% and delivers??? after 2 yr break in, 1 yr warr!
tom
always lookin
tom
always lookin
#23
For me to fully respond to this thread it would be promoting a product while not being a sponsor or vendor of Hummer Forums, which would be a violation of Forum Rules.... which would not be a good idea for a Moderator me thinks.
So much as I would like to share some juicy data and details, I have to pass.
I will share this general H3 info. By just replacing the stock (basically clean) air filter in the stock system with an aftermarket filter (K&N or AFE) it shows nothing, nada on a dyno. The weakest link (most ineffecient part) in the stock system is the resonator box with the accordian style stock hoses/couplers (this also applies to the Alpha Intake with resonator baffles), next is the air filter box inlet as to the 2006/07s, after that it is the filter, then the air filter box. In the 2008 & ups, the inlet was improved and you can mod that very easily to a 3.5"+ adapter, but honestly our testing shows the I5 does'nt need it, an it is questionable whether the Alpha benefits from that as well.
Carry on peeps.
Carry on peeps.
#24
Believe it or not "Mr Sceptical" is seriously thinking about ordering the AidDocs just to see if it makes any noticeable difference. Do you know if adding it causes allot of noticeable difference in engine sounds?
#27
airdoc intake
This is my second H3, My first one was a 07 with stock tires, I put a truflow intake and the pcm for less tune,gas mileage went up 2 mpg,we got 19 on the interstate and a increase in power.I now have 08 with the same I 5 and 33 tires it was down on power and gas mileage 14 and 15 mpg,went with the airdoc and the alpha snorkel, my wife noticed the difference,added the pcm tune and noticed power gain and mpg up to 16 and 18,added the magnaflow exhaust didnt really increase mpg and added the drone that i am getting used to but dont know if i would do the exhaust if i had it to do over again.But I am telling you there is a lot of difference in the power now and all you have to do is test it coming off a ramp on the interstate.I dont need a dyno for that,I can feel the difference.This combo makes the I5 run and sound so much better.I know this 08 would out run my 07 hands down even with the bigger tires.Even my wife can feel the difference.If you are worried about the airdoc ,All you have to do is buy the airdoc with the alpha snorkel and if you dont like it put it on here and you will have no problem selling it.
#28
#29
Your Alpha air filter box snorkel is larger than in diameter than the I5 air filter box inlet snorkel, they assumed you did not have an Alpha.
#30
Thanks ....Now I understand...Bondo
